Trailer wiring?
Ok, with all the discussion about hitches I've seen nothing about trailer light wiring. If you've done it...
Where did you tap in?
Did you use a converter box?
4-wire flat or 5-wire plug?
discuss, please
discuss, please
they did a great job...
Ahh..... I see! You guys were doing it all wrong!
thnx B
Funny, the 7-wire stuff above... I'm a tractor/trailer mechanic,and that standard is ingrained. I just can't make sense of what's posted
Why don't you run the wires out of the taillights, smoosh them between the body and the foam gasket of the taillight then drop them down behind the bumper cover then over to the receiver?
Seriously, how far forward on the car do you have to go to catch the taillight harness before it splits? Aynbody know?
A simple harness like this costs like $10-15 and installed in about 20 minutes for a proper clean look. I love the way mine sits and would not want a harness that sat inside the car and had to be pulled out. With some grease and a cap (like mine) your connections should stay corrosion free and not give you any trouble.
The harness for the lights runs WAY up to the drivers side but the easiest spot to tap is where I did mine behind the panel (easy access).
keep forgetting to take pictures...
maybe this messy helps...
I agree about the connectors; best thing to do when using them is to split and remove a piece of the insulation where the gate will go over that way you avoid the uncertainty of a good connection. They work good enough and it is quite easy as I'm sure you know.
Wally world, $11 connector. Do it, Do it...
NEVER use those blue crimps, I work as a atuo sparky and those connectors fail so often, Yes they are cheap and easy but they dont last, Best way is to solder and heatshrink the joins no problems.
I've even used them to integrate the tail lights on sportbikes. You can find them at wal*mart for under $20. Use solder and shrink tubing! Make sure you have a buddy there to hit the brakes and signals and stuff while you're back there with a meter or test light.
The Hoppy converters come with decent instructions, real DIY type instructions.
I've always been a flat four guy, my girl's camper and my bike trailer are both flat fours. So that means the truck and the van have to be as well.
STEEKERDOOS! that explains it all.
rub it in
if you translate 1:1
plugs in-a box
