1990 d15b2
Hey whats up guys just acquired a 1990 Wagon from a guy my buddy knows. Well he told me that the Wagovan idles and runs fine when its cold. But when it hits runnin temp it will idle weird and die. He seems to think its compression but wanted to get some opinions before I pull the motor and put in a different block.
Thanks, Rich
Thanks, Rich
Doesn't sound like a compression problem at all. Check temp. sensors, IACV, o2 sensor...
Any check engine light? Turn the key on and look beneath the carpet in the front passenger footwell. Count the flashes and report back
check the headgasket.. maybe fine until reaching temp then coolant getting into a cylinder causing a misfire or stall.. just a possibility..check the oil for slug or greenish tint.. take off the oil fill cap and smeel inside..
Let me know if you guys got any input.
Thanks, Rich
bad o2 sensor= too rich
bad temp sensor= too rich
EACV problem= high idle
check air filter? (too rich...)
Thanks again, Rich
Hmm, look for a vacuum leak, too. Would cause high idle and rich as well.
Thanks again, Rich.
