License Plates
Back in the old days of changing your plates out every year, it was prudent to use hardware that didn't rust together. But now, plates here last twenty years, and you just put a new sticker in the corner each year. Well, I'm finally getting my first set of new plates after many years, and had a question for you guys.
I bought some nylon bolts and nuts for this purpose many years ago and never used them because of the shift to stickers. But now.... I was going to use them but then I thought, why make it easier for someone to steal my plates? Does anyone have any thoughts on this strange topic? What do y'all use?
or, for my Euro plated, they are enclosed in a plate frame that clips shut, never to be opened again and the bolts are behind so basically its hard to steal without using man power lol
Most Hondas i've owned the bolts holding the plate has rusted so they usually can't be taken off easily.
Hey, that's a great idea!
Do you read what you post? Sounds like you are the punk kid to me.
He wants to prevent his plates from being stolen and you recommend zip ties? :roll:
I have had my plates stolen and I am neither a crack head or a punk kid either. Mine were stolen because they were put on a stolen vehicle. I was only using phillips head screws but never again.
I now use rivets to secure mine. Not too many thieves carry around cordless drills.
Check out this website, pretty nifty shit!!
http://www.tamperproof.com/
i've seen these on a couple cars at the junkyard haha
screws for app.$15 overhere...
waste of money
never used those exotic bits
Super cheap, easy to install, pretty hard to just rip off.
Not to mention they look pretty racy.
Find the right size drill bit, drill your hole, put the rivet in, slide the gun over the stem of the rivet and squeeze until the stem pops off, and you are done. Take the same drill bit, drill the top of the rivet off and pull you plate off. Most of the time the back side of the rivet will just be pushed out. Sometimes they get stuck but nothing a quick snip can't fix.
After that you always have the rivet gun for other crap
