4wd rear disc brakes bracket?
http://yota1man.tripod.com/vtecwagon/id3.html
custom 4wd rear disc conversion
http://cgi.ebay.com/ebaymotors/Honda-Ci ... 240%3A1318
So it looks like you don't have to hack the rear trailing arm. any thoughts?
okey we need more inputs here people. put some good ideas.
wagon.........................4ever..................
wagon..........................4ever.....................
i beleive 14's will fit coz DA tegs are 14's oe. tegs oe front rotors are 10.31 inches. my fronts rotors are DC tegs and im running 15's so im okey. if i can do ep3 rear rotors/95 teg calipers, ill upgrade the fronts to prelude rotors/legend caliper combo.
ill wait for skinny's rear brake investigation. thanks in advance
wagon.......................4ever.............
RT wheels are 14's
I'm interested in the difference between running a brake booster or not, anyone have some insight on this?
Here's my setup. It really was not that difficult. Unfortunately, it won't transfer over to the RT4WD in it's OEM configuration, since I'm using CRV rear hubs, ITR calipers and the 2 piece rotors. The rotor hats don't place the rotor in the same place as an OEM rotor's hat would. Rotors in my case are 10.75" Wilwood off the shelf rotors that I had turned down to 10.25". The hats are also an off the shelf item from Wilwood. These are the same as the ones I'll be using on the front, but my front rotors are not turned down (full 10.75") and they are cross drilled. The rears will get cross drilled once I get the car up and running, and sort out all the bugs (not a high priority right now).
It took me about 2-3 hours of thinking, measuring and massaging to get this setup to work. I also spent about $100 at the machine shop to get them to machine the brackets "nicely". I could have done it myself with an angle grinder and a drill, but then they would have turned out quite ugly. I started with a 1/2" thick piece of aluminum plate, and went from there. I think most of you guys could figure this out for yourselves, and if you had a welder and some time, you could make them yourself out of steel plate. The only issue with my setup right now is the E-brake. The OEM setup for the cable does not clear the trailing arm. As you all know, the Wagovan trailing arms are quite different from the hatchback, CRX, etc... arms, as pertains to the part that goes up to the upper control arm. Well there just isn't room for the E-brake cable bracket to hold the end of the cable via the OEM routing. I'll sort that one later on as well.
If you go with the 10.2" EP3 rotors, you'll also need to use the ITR or EP3 rear calipers, as the larger rotor will require the caliper to be further out from the hub, and the ITR and EP3 have that extra distance built in (for obvious reasons). If you're making your own plates, that no big deal (you don't need the ITR/EP3 calipers), but if you go with the Ebay brackets, you'll need the different calipers.
Jakers brackets won't work, he's using CRv hubs.
Jakers: Are your trailing arms cut and welded? Looks like you had to splice the front of the wagon to the rear of the CRV? I can't tell if they are welded together because of the paint. It looks like they are just trimmed for wheel clearance.
wagon..........4ever.......................
skinny waht kind of rear caliper are you gonna use for your wagon? and also what disc are you planning to use?
wagon..................4ever.............
I like you will need to wait till the weather gets consistently nice(r) since my motorcycle/bicycle will be my transportation when its down. If you start this please keep a good record of it so we can all benefit. I will definitely be doing a tutorial for mine (like I did with the DA knuckles) when I start. 8)
dude, this is crazy, remember when i was talkin to you about this a while back???
If it was at the meet we had at Edgefield then no, but I can tell you what kind of beer I was drinking. Sleepy Hollow Honey Nut Brown Ale - check, rear disc conversions - doesn't ring a bell
You are gonna have to nudge my memory Andy but as far as the adapter plates it looks like simple work to make your own...
i pm'd you about my friend that might be parting out his 92 integra. i was askin you if parts would fit etc...!!
Oh yeah! Front suspension will go on fine, noahrexion just did this so check out his thread as for the rear with this adaptor plate, I'm guessing it would work, you just have to make sure you have the right diameter rotor but as for calipers they will work.
I hate to be the Grim Reaper. :twisted: The Ebay brkts won't work.
The slotted Ebay brkt are for Post '93 .If I remember right this is also the reason it won't work on the Wagon.The upper trailing arm is at a different angle .For the Wgn. the caliper angle needs to be changed.This doesn't mean we can't use this idea.The eBrake won't clear.Looking at the left rear brakes.All the rear Wgn.rear disc conversions I've seen have the caliper at the 2-3'o clock position.If you look that the following link.Click on to the 1st link on my 1st posting.What he did was to bend the H :evil: LL out of the eBrake brkt.It's a poor pic:
viewtopic.php?f=8&t=2247
A different caliper will be done differently.All the Wgn. probs as far as the disc conversion are caliper related.
comments,reactions,better ideas are welcome.
wagon..........................4ever................................
