How to shave the door keyholes.
Now Im not going to tell you how to remove the door panel and all that. If your not that familiar with your car, you shouldnt be screwing with a project like this in the first place. Please keep in mind, this is how I did it. It may not be 100% the right way, but it gets the job done. If you have a better way, please speak up and let me know. I aint to proud to change the writeup ;)
Stock.
Once your inside the door youll have to remove this clip. Its the rod on the far right and instead of trying to take the white clip off, theres a little c-clip holding on the white plastic on. Slide that off and you can save this brittle little pos in case you want to put the original handle back on. If you dont care, just bust it off. Its faster that way.
Now the rod to the left (above) is the rod that actually moves the striker so the door will open. Its held on by these little white plastic clips (below). Crappy pic I know, but I think the easiest way is to actually pry the rod out of this clip rather than trying to get the clip and the rod out together.
Here is a pic of the back of both handles. Sedan/wagon rear door handle on top and wagon front door handle on the bottom. Notice the rod on the rear handle that goes across the top. That needs to be removed by the same nify clip from above.
Hers a pic with how it should look when your ready to reinstall the new handle. Tuck the rod back inside the door and put the bolts back in the handle so its secure. Be carefull not to spin the little deal on the end, or it might unadjust it. Then put the rod/clip back in the handle.
And heres the end result.
*Im going to redo a lot of this cause the page erased the majority of the writeup during a preview for some reason...something expired?!? and Im pissed, lol.
    You must've left it for a very long time either that or your browser expired it - the forum hasn't had the software for eating posts installed for about 4 months... ;)
    Good stuff. I plan on doing this since I got an alarm now.
  • i always make a copy before i navigate
    in such events ...
    thats is if its a lot of editing, typing etc..
    great write up
    I do usually copy what Ive done before I do another preview, thats how I saved a little bit of it. It happened when I was trying to delete a picture I put on there twice. When I hit the backspace key it went to the expired page prompt.
    The writeup is still missing a bit, but Ill get it in there hoepfully today. Yesterday was actually busy at work...rare, lol.
    so did you just do one side or both? If you did both how do you plan on opening the car?
  • I think using the rear door handle assemblies for the front doors is inspired. I admit I haven't been looking at bodywork or customization for a long time, so perhaps that's just common knowledge. But it hit me like a clue hammer.
    Very slick idea, too. It almost makes me want to add electric locks and windows.
    skinny, I only did the passenger door till I get remote locks etc...but that will be a while. Motors are more important to me right now. I was jsut trying to clean a little shit off the top of a car in my garage, so instead of throwing that handle in a box, I just installed it and decided to share info since I remembered....for once, lol.
    Judebert, ya, this concept has been around for a long time. Its pretty easy in the older Accords and Civics, but the Integras are a little different, just enough to make it a pain. No idea if this is possible with newer cars or not.
  • MikeBMikeB Wagonist
    Judebert wrote: But it hit me like a clue hammer.
    Bwahahahaha! I hope you don't mind if I use that in conversation, Judebert! :lol: :lol: :lol:
    I want to do this too, I already have the aftermarket power locks (which I wish were oem, instead). Should make thieves want to go to the next car, I hope.
