88 rt4wd clutch upgrade
hi everyone.
my 88rt4wd clutch is just about to go south. i did some research here and other sites and found that my spline count is 21 and the flywheel is 200mm. 89"s are 200mm/20 count. 90s and up are 212mm/20 count.
i look online (ebay) for a flywheel/clutch kit combo and only found 212mm/21 count (comes with 8lbs flywheel). my question is can i use a 212mm flywheel? will this have some clearance issue/s. has anyone tried this? also the cx flywheel is 15lbs which im looking into in case if 8 lbs is to light. pls i need some input here bro.
thanks in advance.
wagon ......................4ever.....................
thanks in advance.
Its been a while since I had all that sitting right in front of me, but Im pretty sure the contact area for the 90-91 and the 88-89 are considerably different. I wouldnt spend the money on that kit unless you can find somone that has used that combo with good results first hand.
EDIT... I googled, it's an '88 Accord LXI that has the '88 civic spline count and 212mm. That's the one that will match the 90+ pressure plate and fancy flywheels to the '88 transmission.
im still in the drawing board so to speak, so i would appreciate for more info from you my wagon bretheren.
wagon..................4ever..................
viewtopic.php?f=7&t=1280
It was in the above link,''Drivetrain Quicklink'' under,''Which Flywheel?''.
judebert's thread is very informative but he doesnt use a starter so as far as the total flywheel diameter, it may not be the same. i found on ebay 21 spline/ 212mm with flywheel, so just maybe the 92 flywheel will just work. i just get the 21 spline disc.
thanks again, if you have more ideas or info, pls let me know.
wagon.............................4ever..................
same here. there's always the thirst for knowlege i can get rid off.
pls someone or somebody with the info requested please.
thanks
wagon................4ever.......................
thats all for now. chow
wagon...............................4ever................................
