Rubbin' (not affectionately)
A couple of months ago I notice when I stop suddenly I could hear the tire rubbing on the inner fender, it didn't do it very often so I didn't think much of it.
For the past month it has gotten a lot worse and almost to the point where any kind of stopping makes the tire rub and squeal.
This past weekend I had an old known good stock shock that I replaced the old one with and thought that would take care of it, it didn't so now I'm confused. So would it be the replacement shock I put on there that was bad or would it be something with the spring. The shocks are Tokico Blues shock/spring combo on my '88 wagon.
I've had the shock/spring combo on the car for about 2 1/2 year and it just started within the past couple months, just started getting really bad within the past month. Tonight on my way home from work everytime I pressed the brake it squealed and I started smelling burning rubber.
Either the bushings in your front sub frame where the radius rod attaches are toast, or the bolts that hold the radius rod onto the lower control arm are gone.
When I swapped the shocks I did notice a nicely shined area towards the rear of the fender (splash guards are long gone so it's just rubbing on the metal).
I'll probably have to take it back apart this weekend to look at the other parts to see whats going on down there. I didn't take it to work today after smelling all the burning rubber last night, thank goodness for backup cars.
I don't suppose you could supply me with some pics of the parts your talking about, I'm clueless when it comes to suspension.
I was looking at www.hondapartsdeals.com for the parts and it says you need an awful lot of parts.
If you look at the pic and then the link below it says you need 4 of the bushings, 2 collars, 4 washers and 2 nuts? Is this right, does it need all these parts for one side or is this for both the right and left sides and would I only need half this amount?
http://www.hondapartsdeals.com/hpa_part ... vin=&Label[ProductID]=CIVIC&Label[YearID]=1988&Label[DoorID]=5&Label[GradeID]=4WD+(1600)&Label[AreaID]=KA&Label[TransmissionID]=5MT&Label[SectionID]=CHASSIS&Label[IllustrationGroupID]=FRONT+LOWER+ARM&ProductID=4&YearID=27&DoorID=3&GradeID=79&AreaID=2&TransmissionID=3&SectionID=6&IllustrationGroupID=6497
Ha, yeah I lost all the washers, collar, nut and bushings. I guess the nut at the end came off somehow and everything slid off.
So if I'm only doing one side I'd just need two bushings right?
2 bushings
2 washers
1 collar
1 nut
per side
YAAAAY Thanks, I need to put that order in tomorrow so they'll be here Thursday so I can put them on this weekend.
I discovered that there was a problem as I was pounding down the on-ramp onto the highway doing something close to 1G at about 65-70 mph. It was a somewhat uncomfortable feeling when the front end started wandering around at the limit. When I got home, I found that both bolts on the passenger side had pulled out and were gone, and the driver's side bolts were "quite" loose. Lesson learned!
I was at my parents house today checking on the house since they are away and as I was going up the hill leaving the car starts pulling severely to the right and the wheel scraping. I turned around and parked in the grass in front my parents house and check under the car, the tie rod snapped in half.
Anyone know if the tie rod is universal for all EE/EF's? I checked Honda Parts Deals and they are only $32.
I'm never leaving my car at my parents house for a week and a half, it was yellow when I picked it up.
