someone clarify my clouded mind.
first, i've done all the research and i've read all the articles (old and new forums) and i'm just as confused as a cow in a pig pen.
my wagon has over 400,000kms and lots and lots of cancer. it is hardly worth spending any money on. All 4 shocks are toasted, i have spare front ones off a parts wagon. The rears however, have me slightly perplexed in some regards. I want to replace them, i have about 10 various DA & EF parts cars. Now, which spring/shock combo can i use from DA & EF to bring the rear end back to a good ride, with a near stock ride hight. looking for as close to stock as possible. yes i am cheap, no i don't want to invest any serious money into this car. My time spent on it is already a stretch.
it is my understanding that an EF rear w/ DA springs will bring it back to stock'ish. true/false?
thaaaanks.
thaaaanks.
clsmooth
clsmooth(one of the cool OG from the old site).I still remember he put 4 Si(I think) seats in his wagon.I'm pretty sure he was refering to OEM Wgn shx.A uncut DA spring on a EF rear shx will probably put you in at 3-4 inches(75-100mm) higher than stock.If you cut the DA springs to fit...it'll b way too stiff.
Your cheapest choice would be a EF rear shx & spring.If you have a set of civic sdn. springs.These might be a little stiffer.
your best bet would be to go EF-EF, not do mix-and-match. If you dont have rear springs, go to local junkyard and try to find some. Like Si said, even sedans would work, but Hatch would be best. hell, you might be lucky and stumble upon another wagon at the junkyard. then you can get all four, and even maybe some replacement parts for all that cancer.
