overheated engine question?
if the d16 overheated, will only the heads be warped or will the whole engine be warped ?
to clearify
heads = where the valves and springs sit in
whole engine = bottom section (includes where the piston can crank sit) and heads
if its the whole engine then thats understandable.
if the answer is just the heads are going to be warped,
my next question is why doesnt the whole engine get warped?
to clearify
I did work experience at an engine rebuilders, over a year I only saw one case of a warped block, but that was from a 1970's holden (GM to you guys I guess)
Most of the time the head can be surfaced and will be all good, will even have a slighty higher compression ratio
what did you use as a straight edge to see what the clearance was for the block and head?
i am also being suggested to get cometic as my next headgasket, becuase i can get custom thickness vs. eom honda headgaskets.
any pros and cons with getting custom from cometic.
(im thinking of a little thicker then oem)
"whole engine" if needed can be resurfaced too...without the chisel...
"gaskets" composit versus metal
clearance versus tolerance ...
then which one do you think would be best for my application?
since i am able to easily re surface the heads, the engine bottom is not soo easy. so i would like to try to avoid taking out the engine. so which head gasket should i get to help cover up the bottom end not being resurfaced. ( i have not checked it yet. i do know for sure the heads is warped for sure tho, not so much the bottom end.
DO NOT STACK TWO HEADGASKETS ON TOP OF EACH OTHER!!
then you can wait and see ...
i have never heard of the spray. do you have a brand and a link to a site where i can read up on it more?
permatex- copper sray, most parts stores will have it. i always use it, every time for the head gasket, also is good for the header/manifold to block gaskets. 8)
Yep thats the stuff! There is also some other stuff that isn't copper, I'm not sure who makes it but it works just as good. The copper helps distribute the heat.
Here is a pic of the copper stuff:
http://www.carshopinc.com/popup_image.php/pID/42287?osCsid=5b2702073b59935b3547b8f593f54df2
