91 wago, awful reverse noise
the car runs flawlessly and shifts great 1-6. when you start moving backwards in reverse however it makes a awful noise. its a hard noise to describe but its sort of a loud whirring... the car also shudders when this is happening.
anyone have any ideas? or is there more info i can give to help narrow it down?
thanks a ton
thanks a ton
so reverse gear teeth are cut like this |||||
and the forward gears are cut like this ////
It's not the normal reverse whirr.
Oh right.. Mine is ok, just makes a rumbly click(kinda like a rooted cv but not) noise from the diff when turning right
It's fine, mine started doing it at the sand dunes and did it constantly for a year later till I sold it. don't worry about it, it's just noise for now.
Then one day it locked in reverse (the tires locked) and the car stopped.
Two weeks later, the gearbox spread its guts all over the freeway...grenaded a hole in the trans.
