brand wise....im using Skunk2 coilovers. you could use GroundControl too, even Tein. if you want lowering springs, there are many brands out there, just depends how low you want it. Eibach is a popular brand, with either their pro-kit or sportline kit. like i mentioned earlier, it really depends what you want and what your budget is.
do some research around this board. you'll find a lot of options you could use.
a good tip to ALL noobs.....do your research. if you cant find what you need then start a new topic. if you have questions on a existing topic, please post in that topic. this is to get around cluster on the board.
use springs for the hatch
http://www.hondacivicwagon.com/board/vi ... .php?t=594
