so what should i do...
ok, so im pissed and tired of trying to get my JRSC to work after about a month. i know its only going to cause me more trouble, seeing as im not boost savvy and just not in a financial situation to be able to maintain the things that go wrong with it (for example, the damn pulleys are shot). also i dont have the time right now and i need a DD seeing as im a full time architecture student without a job till the summer.
so here are my options...
-go back to stock, keep the JRSC and maybe i'll learn the magic touch that's keeping me hanging by a thread and making me pull my hair out.
-sell the JRSC and get a new motor instead. this raises more options:
1.) get a classic ol' DOHC ZC (i want to stay OBD-0. lets keep things simple.)
2.) get a SOHC something or another, like ZC VTEC or a D15B (but then i need to go OBD-1.. more headaches)
3.) go B-series, like a B18A or something.. but then i need mounts, and shift linkage. (just more spending)
4.) go K24
jk.
so yeah. also then i would have a spare engine finally to throw into my hatchback project car thats been sitting forever waiting for a heart. then that could be my DD instead.
then i could possibly boost the wagon later :roll:
also, its looking promising that my friend will be giving me a spare D15B1 with about 80K miles on it. so it could be a spare engine to rebuild, or put that in that hatchback..!?
so what should i do eh? im personally leaning towards the DOHC ZC
or B18A
4.) go K24
I would keep the SC if I were you. I know how shit gets discouraging, but you are probably closer than you think. I personally would rather have a B18B and go OBD1 and tune it with an I/H/E.
Of course you could go DOHC ZC/B18A for really cheap in comparison. Just a lot more work when you already have done half the battle with your SC setup. What is the issue now? How much is that thing worth? How much do you realistically think you can swap a B18A or DOHC ZC for? Don't forget things like coolant, oil, clutch, flywheel (at least resurface), trans, ECU and all the extra junk that goes with the swap.
read my original JRSC post...
H-Motors has them for $650. i can use my stock trans and get ECUs for $26 or so (like a PG7). coolant and oil is pretty easy to get
right now, unless i figure out whats wrong with my setup by tomorrow morning, im going back to stock at least for now. like i said, i need my car. *sigh*
yahay
My suggestion would be B swap, but of course I'm biased.
ha ha ha thanks man.
here is a picture of me you'd appreciate ...
i did the MPFI swap like 1.5 years ago and the car was running perfectly fine. put about 12,000 miles into it with the MPFI swap.
i would love a B-swap, but for now im trying to get the simplest (and mostly cheapest) replacement engine with more get-go.
your swapping sux
ding !ding ding !
yeah yeah...i know...
below the belt...
can i do it again?
i know how discouraging it gets.....
but in the long run you will be happy if you stick with what you started and build the blown D-series. it just feels good to see it come together, ESPECIALLY after it seems like it wont.
Where can you get a PG7 for $26, I need another one.
Fist one I got off the Southeast Honda-Tech classifieds from Jedburg, SC and second one I got from www.thezcr.com in Greenville.
You can check either of those sites or http://www.importatlanta.com/forums/ that might be closer for you.
http://www.hmotorsonline.com/shop/sc200 ... item=30020
88-92 DOHC
http://www.hmotorsonline.com/shop/sc200 ... item=30022
The dohc is the same price you said but the SOHC is quite a bit cheaper.
I can get you those EDM ZC ECU's but you know that. If you end up getting it and need anything else hit me up.
yeah i may need an ECU for sure. thanks! i'll let you know what happens. any word on the german dude and the JRSC?
Whats the difference between the JDM and EDM? Is it the speed limiter on the JDM? I might be needing a DOHC ZC ecu but that won't be for awhile so don't go get it now. Don't want you to have to hold onto it for me.
If anybody can I can source a EDM ECU if anybody can compare the chips.
How about you learn TurboEdit and chip obd0? Why convert to obd1 unless you really have to?
