has to be the easyest mod ive ever done to my wagon
ok hmmm, ive been putting the whole rear swaybar thing on the backburner for a long time now, mainly for the fabrication part of the whole thing. so yea took me like 20 minutes wow soooo hard :shock: i can see if you didnt lower your wagon you would slightly have a minor spacing problem, i dont even have the lowest drop at all and it was a total bolt on affair, other than drilling one extra hole each side on the chassis for the brackets.
anyways, anyone that has a swaybar and has been putting it off take 20 minutes and bolt it up there! rides great
i posted this on a different thred because the sway bar link is some good info but some of it just goes way to for into fabrication and wanted to let everyone know 20 min at the most, well if you use crx/hb si bar that is 8)
ill put some pics on that thred when i get the time.
PROVE IT!!! I want PICS!!!!!!!!!!!!!!!!
???? hmmmm must be sniffin that yayo
Exactly
ill take some with my cell phone tomorrow i guess, they cant come out any worse than my messed up digicam
you dont have to put the link in the front of the lca like factory does, seems to work just fine for me. while it clears the rear sub frame i did hammer the seam in for some extra clearance i will clean that up a little when ive got time
i will add my way to the real rear sway bar thead and take a step by step as well, seem my new cell phone takes ok pic's hmm kinda surprised
