Help!! getting ready to dyno my rt4wd!
hey guys i need some help im almost done with my d16z6 turbo set up, only days away from needing dyno tunning so how do i do it!
? do i do it in 4wd on an all wheel drive dyno? or shut it off and do it on a front wheel drive dyno? wich way is best to get the most accurate whpand less likely to damage my tranny? thanks alot for all your help guys!
I'd suggest 4-wheel dyno just to make sure.
Either is fine actually and the only real advantage to the 2wd dyno (so long as its a dyno dynamics than its as good as you can get anyway) is that it may be cheaper hourly rate on a 2wd.
Yes u can run it in 2WD!When u disengage the 4WD.All it does is disengage the gear to the rear.If u look at exploded views of the 4WD tranny you'll see what I mean.
I would dyno in 4wd though, it would be more accurate. You are carrying around all the weight for the 4wd anyways, might as well let the back wheels do some pushing on the dyno. I don't think it would be logical to say you WHP in 2wd is what you car is running. Everytime you spin the tires and your rears hook up you will probably take a hit to your WHP. After its tuned, I would find out what the WHP is with 4wd engaged and thats the WHP I would go with.
And 4wd is not going to make your engine run lean or rich!!!!
WRONG
And how the 4wd works on our cars:
If the driveshaft from the transmission to the Viscous Coupler spins any speed different then the driveshaft coming from the rear diff to the Viscous Coupler, the VC engages. Once start spinning those front rollers and the rear rollers of the dyno arent spinning the same speed, the VC will engage and you will be in 4wd. Something I just thought of though, if the speed of which the rear rollers coast to a stop is different than the front rollers that might keep your VC engaged. Maybe I'm wrong by saying that force on the rear wheels can drive the 4wd all the way up to the transmission. <
WRONG
To bad an awd dyno doesn't work that way. The rollers are constantly matched; you could put a 2wd car on a 4wd dyno and as long as your e brake wasn't on your rear would turn at the same speed as your fronts cause they are linked via another.
2wd driving and dyno tuning is fine; I cannot imagine any ill side effects running 2wd pull after pull after pull for power or tuning... it doesn't matter. The trans can still hold the same amount of power regardless of whether or not its in 4wd mode. Furthermore, a properly hooked up car shouldn't really be spinning too much and you would thus be 2wd anyway. When/if any time you are spinning and the rears kick in you won't notice much difference in power anyway, it will be as seamless as the transition from 2wd to 4wd is.
So can someone at least agree with me that to get the best tune and realistic numbers, it should be run 4wd????
I forgot about the lever on the tranny and always just dynoed mine with the bolts out of the driveshaft.
so i should still disconnect the 4wd to be safe right?
But you are carrying around the extra weight so might as well make use of it.
Do you think you're only gonna do one run and have all the kinks worked out? You might be there for hours do numerous pulls, it'll take you couple minutes to switch it between 2wd and 4wd.
rrev or vip not sure yet
If there is a difference in rotation speed between front and rear, it sends power to the rear. If the rear is sitting on concrete what will happen?
The wagon is going to do one of three things...
-break traction in the rear to keep up
-push itself right off the dyno
-fuck your transmission and vc because of the massive load it all of a sudden has to try and push
As far as i'm concerned there's only one way to do it - 4WD dyno with 4WD engaged. That was you'll also defeat the mentioned lean out issues.
And if it was on speed matched rollers on the awd dyno, how is the coupler/diff gonna act? I would imagine that as long as you dont break traction its going to stay in fwd mode the entire time since the rear wheels are going the same speed as the fronts.
What I would be worried about is it what happens if the car breaks traction in front? If the drums speed up to the catch up with the fronts and engage the rears youll have a heavy weighted drums fighting your diff/couplers. Just seems to me that since the awd isnt constant, that the rear wheels would be somewhat fighting the drums. Id hate to see any damage happen as a result cause the heavy ass drums arent going to give like the diff and couplers will. Hell I dunno, I could be way off here, but I thought Id mention what came to mind.
When I did my car the first time I had free acces to a dyno. The car was setup OBD1 and I had a chrome program for the valvetrain I installed. Put it on the dyno and the program was almost dead on with the exception of being just a tad fat at idle and just a tad lean at 8500+rpms. We dialed it in and moved vtec around till we had the magic combination of what looked best on paper. Then I hooked the driveline (CRV tranny) back up and put a wideband on it and went out in the real world to fine tune it with a AFC. The car on the street with all four wheels engaged had almost the same readings as the car on the dyno in fwd mode. We had to take out a little more fuel down low, but other than that, it was right on the money.
Another thing that came to mind is even though the car will have more load on it in awd, the only real time your going to be using it is off the line where youll have your rms up anyway. If the rpms are up and your in launch mode, I cant see it going lean enough with the extra load to affect anything when your that high in the rpms anyway. Again, I could be off here. Just throwing out ideas.
Actually you are right on the money; not only is it crazy to me to think that once the "4wd kicks in yo!" that your car will lean out and cause problems; but you definitely will be running two rollers with only two wheels if you run on a 4wd dyno.
If you DISengage 4wd from the lever near the speedo; you will NOT be putting power out the rear: thus you will NOT send any "message" to the VC to kick anything back to the rear wheels. Definitely do not run your car on a 2wd dyno without disconnecting 4wd first. You can verify 100% that it is disengaged if the output shaft is NOT spinning. Your car is totally fine to dyno on a 2wd dyno if you do this.
Like I said before, if you dyno on a 4wd dyno you will NOT be spinning/loosing traction on the rollers (unless you are making some stupid power) THUS the rears will not have ANYthing sent back to them. The rollers coincide with one another so your rear will be spinning the same AND your fronts will be the ones powering BOTH rollers (more load on the front that is 99% the case when you will be driving on the street).
sweet! thanks for the info!
lol thanks bro yea i ordered 2 inercooler pipping kits just to make sure it looks clean
Based on the gear ratios, the fronts can only slip 0.12% (yes that's right, less than 1%) before the viscous coupler starts to lock.
