Exhaust question
Will the Civic/CRX/Civic Hatchback exhaust fit on the Wagon? I'm getting sick of the loudness of my exhaust, and would like to get a nice cat back system or something.
Does anyone know any good/cheap brands that will make is sound good without sounding like an annoying buzzin bee? Thanks
You could have a system custom fabricated for a pretty reasonable price at a muffler shop.
I like to buy my own components so I know the results are going to be worth the trouble. Once you figure diameter out, you'll need:
Resonator...nothing fancy. You can even use straight-through bullet style mufflers like Cherrybombs ($15-20).
Muffler...something high quality, stainless with at least two chambers. I got a brand new Borla off Ebay for like $75 shipped.
Tip(s)...to take one last opportunity to silence any harsh noises, I like using resonated tips. Check Jegs or Summit ($15-25)
Mandrel bent elbows...most small, local muffler shops won't have a mandrel bending machine or the pre fab elbows. So buy a couple 90 degree or even 180 degree pieces from Jegs/Summit. Or you can skip this and just let them crush bend the tubing.
After you lay all theses parts out and the local guys just need to weld them together, I wouldn't spend more than $150 for the labor(2 hrs).
As Davens said, best bet would be to get one custom made - that way you get exactly what you want.
Before the trailing arm, NO. You could just go to a custom exhaust shop and have pipe made to fit your need.
Would you like me to make you one? If so let me know what type of material you want, size piping, if you want a cat, resonator, ect.?
Ill do it cheap for you and follow all factory bands.
It just seems that a straight exhaust system would flow better than one that has a bunch of 90 degree angles in it.
I was looking at something like this:
http://cgi.ebay.com/ebaymotors/Megan-He ... enameZWDVW
It seems to have everything in it that I would need, just bolt up and go.
Don't knock the ugly weld. I really didn't want to post this pic but it shows where I cut the exhaust to weld on the new muffler. I don't think it turned out that bad considering it was my first weld job. At least no leaks. I still have to weld on a hanger so I can get rid of that rigged hanger I put on there.
RSR claims they have a quieter exhaust system..anyone know more about this particular exhaust than what they've posted?
ExMag features
- quietest exhaust note on the market (most applications)
- refined stealth like appearance
- ceramic coated mandrel bent piping
- dyno proven gains in horsepower and torque
- engineered in Japan
- signature RS-R exhaust tip
- constructed with 409 stainless steel for long life
