New Paint, same old color
Last time I painted my car was probably about 2 years ago. Since then the paint has faded, it’s gotten some chips taken out and someone back into me on Sat night in a restaurant parking lot so I figured it was time to repaint.
I picked up some odorless mineral spirits and a quart of satin black Rustoleum paint. Last time I painted I used a $14 Harbor Freight spray which I tried to use this time but it was clogged, guess I didn’t clean it well enough last time. I had an older DeVibliss gun that I had laying around so I chose to use that one.
Since the car had already been painted with Rustoleum before all I did was give it a good wash before taping it up. After taping off the car I used a Wal-Mart mix bucket to mix the paint about 60% paint and 40% mineral spirits.
First coat of the paint went well but I don’t think the gun was adjusted correctly because I got a few runs but overall the spraying part is pretty easy and went on well. I did about 3 coats but probably should have done 2 more but it was getting late. I did notice the back of the car where it got a little more paint does look a lot better and darker so I might reapply more paint later.
Since the car seems to fade after about a year I did buy some Krylon Satin clear to see if that would help. I did a test spot on the front bumper, let it dry and came back, it was kind of shiny and looked almost like glossy clear. I had some left over paint and just painted over it.
Before
During
After
  • StockStock Wagonist
    I dig it. 8)
    looks pretty good, should have used a single stage paint and maybe painted a glossy black...
    looks good regaurdless...
  • I definitely dig it, I also dig the NA miata 7 spokes. What did you do to bore out the wheels, just grind them away? Did they balance well? I like that look a lot. You know I agree with the whole single stage thing. If you have a compressor and just about any sprayer 3-5 coats of any single stage generally comes out "nicer" looking if you know what I mean. Granted you are painting outside so you probably don't care too much.
    Don't you think it'd be easier to remove some of the things you so carefully masked off? I thought the handles, lights...etc would be easier removed then masked off. I just primered and then coated a few tiny rust spots on my rear fender in preparation for a Spring time full paint.
    Thanks for sharing, looks like you had some agreeable weather!
    Thanks, I wanted to keep the satin look because I really like it and plus I'm really bad about washing my car. If it's satin then you can really tell if it's dirty or not and since I use the wagon almost like a truck it's not very clean.
    I just used a hole saw I picked up a Lowe's and pressed really hard using a hand drill. I haven't noticed any problems with them balancing since I put them on over a year ago.
    I prefer the cheap Rustoleum method because it's cheap, can touch up if I need to, don't need a booth or garage (both of which I don't have) and I can do it outside. I did notice a couple of bugs but they go away eventually. I have tried the single and it didn't turn out very well. I'm pretty inexperienced in painting and I guess the Rustoleum is a lot more forgiving. When I did the single stage it came out pretty bad and almost ruined the car so I haven't wanted to try it again since.
    I guess it would have been easier to remove those parts but I was kind of in a hurry and almost had to drive it 30 mins after finishing painting. Removing the tape afterwards was a lot quicker and only took about 10 mins to get it all off.
    It was nice, about 60 degrees and sunny
  • looks nice, i really like the new south carolina plate. :mrgreen:
    Thanks and I'm so glad they got rid of that "Smiling Faces Beautiful Places" crap.
    haha true. i wish it wasnt flat though.. looks cheapo. -i have yet to get my new one.. in May
    They look like they're paper but do look better. I got some paint on mine and was using some acetone to remove the paint and was afraid the numbers and letters were going to rub off, I did erase a lot of the 11 on the month sticker and I'm sure I'll get pulled over for that.
    Look out for that extra $25 charge in April when they send you your tax bill for the new tag.
  • emofiedemofied Band Wagon
    Looks great, tasteful, non-rattle can flat black. I like it alot!
    Does Rust-Oleum make a flat red? :o
    Cool. Are you bringing it to Savannah march 8th? :)
    I didn't see any flat red on the Rustoleum site, they do have flat white
    I forgot about that, where in Savannah is it going to be at.
    Mind shooting me a link?
    Yeah, I got that much, I'm not sure which type of paint I'm looking for...
    the Visitor Center parking lot will be our meeting point. literally right at the end of I-16
    yeah, yeah. I think wagondriver is still coming down from Cola, too.
    Oh wait I think I found some satin red
    http://www.rustoleum.com/CBGProduct.asp?pid=162
    This is what I used, Rustoleum Protective Enamel
    http://www.rustoleum.com/CBGProduct.asp?pid=150
    I might be able to make it, depends on how the wagon is doing, it leaks oil like a MF and haven't figured where it coming from.
    Awesome, thanks!
  • Stock wrote:
    Awesome, thanks!
    hit up paint specialties. They'll mix you up some cheap ghetto flat red. They'll even match the honda red in a flat.
    Really? That simple? Cuz you see, my other car is a Miata, and it would be VERY useful if its wheels would fit on my wagon and my gf's CRX... Also got a line on a cheap set of Miata wheels, though the LAST thing I need right now is yet ANOTHER set of wheels... :lol:
  • ilovemywagonilovemywagon Band Wagon
    Very Nice. Good job. :)
    Please stop bumping these old threads :roll:
