speedo cable. another stoopid question
Once again. My manual doesn't help me at all.
My wagon got a new clutch about a month before I got it. The mechanic that did the job forgot to re-attach the speedo cable to the transmission.
So I flip opened my worthless manual to see where and how the cable attaches into the trans. It doesn't cover it :x .
I looked from the top side and didn't see anything obvious.
So where does it go?
so far I've got away with guessing how fast I'm going? I have a feeling my luck will run out before too long.
    This apllies to 4WD too.
    Look under:
    Transaxle,then
    2WD Manual Transmission,then
    Transmission Removal,then you'll see
    it labeled,''Speedometer Cable''
    Pg 13-4 on my manual(mayb diff. on ur manual)
    Look under:
    Transaxle,then
    my manual ends at 12-32.
    went to the transaxle removal section
    " 6. detach the speedometer cable and electrical connectors from the transaxle".
    That clears it up for me :? .
    I currently carry this in the wagon in case I need something to start a fire with. Or in case I have to use a public restroom and theres no toilet paper. :)
  • and theres no toilet paper
    what happened to that fluffy rabbit ?
  • what happened to that fluffy rabbit ?
    I've got to say Eagle Beagle, that you always produce the most colorful posts! Sometimes I'm not even sure what the hell your talking about :lol: .
    There's a flat level are on top of the diff. side of the transaxle, just above where the axles go in. sticking straight up out of that flat is a little gold-colored tube- just big enough for the cable to stick in. Stick the cable in it! The ferrule on the cable has a groove which corresponds to a slot in the speedo drive(the tube thingy). There's a funny little wire c-clip that goes in that groove.
    Here ya go. Went out to the shop and got a pic.
    the clip:
  • damn... can't get any better directions than that!
    thanks for your help and the pics!
    Tomorrow... I will know how fast I'm going.
