Who has broken a drivetrain before?
I am about to buy a Shuttle 4wd box to run in a Civic 4wd project, and i have some questions regarding gearbox strength.
I have read much about these boxes, many people have opinions, few people have facts. Many people consider them 'weak' but it has been proven that they can stand up to both turbo applications and a locked 50:50 front-rear bias.
My question is, when they break, what breaks first? I will be running somewhere in the region of 200-250whp when the car is finished and will probably keep a centre diff of some sort, not necessarilly a shuttle one, with a modified control system to better suit a race situation.
So, when you lunch a drivetrain what gives? Transfer case? Rear diff? Rear driveshafts? So far I have yet to here of anyone actually breaking something, which is quite an encouraging start
But again, it depends on how you drive it, launch it, abuse it. I've said it before, DSM,Subie, and Audi guys have all blown something in the drivetrains(and our systems are not near as strong as theirs). No one system is bulletproof especially a 20 year old rt4wd system. My suggestion is to choose your parts wisely and rebuild or repalce drivetrain components as needed.
btw, welcome to the board.
I am intending to install the Wagon box and take it from there. If something breaks, build it stronger.
So far we have transfer case as a possible weakness, anyone have trouble with rear diffs?
why not go with a b. if you are going to do all that work why not put power with it. you have a lot of work to do. have fun with it.
The Standard L3 civic/crx transmissions are not know for their bullet proof nature. I consider them the achilles heal of the otherwise energizer bunny-like D16a6. So aside from the standard bearings and synchro problems, my vote goes for the transfer case.
I say the transfer case because its the only bad wagon tranny I've seen in person (fragged to bits in a junkyard). And considering what it does, it just looks fragile. The RT4wd system is Honda reliable at stock horsepower, or even with some decent mods, but when you start doubling power and mixing in some strenuous competition, something is gonna give.
If you lock that in, its a different ratio to the front (almost half), therefore your building pressure up.
Again it can only be speculation, but the other part i see as being weak is the shift forks.
Welcome, Colza! I'm Haydz on NZHondas...
