Air control
I've been getting really frustrated at my wagon...and even though it isnt running right now i want to go ahead and fix it.
Half of my air control cluster is broken, the fan speed 1 and 2 dont work.
and the air direction switch does not work either.
Will any of the air control clusters work from any 88-91 civics?
    Fan speed prob is pretty easy if you got a soldering iron.Please do a search b4 askin a question.Type in,''heater resistor'' under forum,''Electronics, Fueling & Air Conditioning''.Your answer is there.If you found the right thread just read my postings for a faster answer.
    Air direction switch?? Are you talikin' about the slider?If so follow the cables to see what came loose or broke.
  • Yes - sedan, hatch, wagon HVAC controls interchange. Mine came out of a sedan.
  • Instead of started a new thread, let me ask this here.
    My blower is really weak and I need to fix it, is my best bet just to buy a replacement blower for a Civic? Or is it possible to swap in an Accord blower to try and get a little more power?
  • @EFin
    i would check inlets, ducts/leaks, clean blower/lubricate under glovecomp.
    not that much hassle before buying
