washer trick(solved)
Back wheels are tucked like crazy after dropping my car.
Need to do the "washer trick". I've read that the bolts are too short and that I need longer ones. Anybody have any specs on what size/ length bolts I need?
careful those holes will strip out real easy, take your time
http://www.hondacivicwagon.com/board/vi ... php?t=4390
The info I am looking for is just the bolt size that I'll need.
ie. M12x1.25 30 or something of the sorts. Just being lazy. I figured if somebody knew off the top of there head It would save me pulling a wheel, pulling the bolt, measuring, then putting it back together, driving to get the hardware, etc.
I'll post what bolt it is you need when I pull one off.
