d15b vs 16y8 = NO AWD ***EDIT***
think of doing a swap...
im looking for pro's n con's
easy vs hard (as in the swap)
best bang for my buck... (and i want to stay single cam+awd)
i have a d16y7 that i swapped in without doing the mpfi so that i could leave the stock ecu and intake. i needed easy and cheap when i did it and thats what i got. i am going back in soon and wiring the mpfi and changing intake mani and ecu and also cleaning the engine bay a bit.
none of it is really hard so far but i have someone with a lot of swap experience available. with the y8 it gets a little harder because of having to wire the vtec, but that really the only extra step as far as i know.
my little dab of knowledge, hope it helps.
Wow did unstickying your engine theory topic hurt your feelings? Get over it.
Anyways my personal opinion is that the Y series engines are junk when compared to all other older honda D blocks. In my 8 years at my current Honda-only shop we have replaced literally 20 or so Y series engines all due to rod knocks, while all other 88-95 D engines combined we've maybe done 2 due to rod knock, and honestly they might have been ran out of oil.
Nobody has ever really pinned down why Y series blocks end up with rod knocks, but trust me it's very common. I'd use an 88-91 D16A6 block over any of them, but if you must buy a complete engine from an importer that comes with a warranty get a SOHC VTEC ZC as it is just like our D16Z6 - a much more durable engine than any D16Y series.
Hey I was just researching some stuff about this and found a couple of good theories. The one that makes the most sense with me is: Y8 blocks were built a little less expensive then their Z6 counterparts. The oil pumps made less pressure than the Z6 and oil passges in the block were subsuquently ran with a smaller diameter to raise oil pressure out of the the pump. And from what I read on some other forums, it seems as #4 cylinder is the worst for this problem. So oil starvation=rod knock! Just some information I've read, don't know if it holds water :?
from what I've read a long time ago, the d16y8 motor has the highest compression of all d series motors. I'm a noob at motors so, thought to give some knowledge of what I know. But a lil question, my co-worker was stunned to see my wagovan and asked if i was planning to do a swap. I said a Y8 but he said a ZC. Now im thinking a ZC is the same motor as a B18b (LS) correct? BUt it's JDM, how will that pass CA-emissions? Since after this year 86 cars dont need to be smogged. i'm think have my final smog check done and have some play. But any1 who can help me out with the whole ZC being smog legal in CA, let me know, thanks
black top has some say 130hp some say 138 i say 135 call it a day
olive top has again some say 128hp and some say 135 i say 130 call it a day
black top is a trick for getting the right parts:
88-91 prelude timing belt
86-89 integra head gasket/intake manifold parts distributer/88-89 only cyl sensor
headers from any d-series will work but some need a little honing to line up other wise its the teg for perfect fit
88-91 civic sohc waterpump and if i remember right oil pump
its kinda a mut of sorts motor but when you know what to buy its a great motor that bolts right to you d-series trans if you have to.
olive top is all 86-87 integra parts with a 85-87 style trottle body but its easy to swap to the newer intake manifolds headers are the same story as the black top. also a great motor somtimes people confuse these for the usdm motor but we never got this version of the motor for our were rated 113/118hp this motor only bolts to 86-89 teg trans and is generally only used in the 84-87 third gen civics
this motor has got some legs and it is as fast as the ls in my opinion plus its a drop in and have fun deal with only 2 wires to move to the cyl sensor if you already have mpfi
way better gas milage than the ls
anyone out there who has some info i left out feel free to chime in this is a great motor for a dependable and fun ride.
It's not true that the OBD2 series motors have higher compression. .2 higher compression really isn't significant. I'll have to look at the specs again and compare them but I'm pretty sure that the OBD1's are around 9.2 and 9.4 and the OBD2 are around 9.4 with one of them being 9.6.
The OBD2 heads are far more efficient than the OBD1. They have better quench area and the secondary intake valve is opened slightly less. This swirls the mixture and squirts it into the center around the spark plug resulting in a more complete burn with less chance of abnormal combustion (ping, knock). As a result the OBD2 D series engines require much less ignition timing advance to achieve MBT.
whats up man
so no luck with these motors due to the "intermediate shaft" and the only thing good about the y8 is the head :shock: thank you...
ps...
sorry about you sticky :oops:
what about the sohc ZC??? the reason that i ask is im thinkin that this is going to be the route that ill take but now its a matter of vtec vs no vtech
I have a bit of info that might help out as it did for us. The OBD2 SOHC VTEC heads use the the same bolt pattern on the dist as the D16A6. So you dont have to mess with modifing the tabs for it to bolt up. HTH's at least one person, lol.
I might have found a way around this, but not for sure as of yet. Ill chime in after I get a chance at install. The block has one tapped out hole ready to go for the int shaft, and I think if you use the bottom bolt holes from teh intake manifold support you can make a plate bolt up and have a place for the other two bolts on the int shaft. Crossing fingers as I allready own the D15B.
CHECK IT OUT...
***STICKY***
http://www.hondacivicwagon.com/board/vi ... highlight=
There are a number of SOHC ZC's. There is a D16A6 clone, a D16Z6 clone, and possibly even more beyond that.
so does it matter which SOHC ZC i get>>> the reason i ask is when i call the motor yard they just asked which year i neeeded vs an engine code (ex. d16z6, etc.)
Yes, the engines are very different. You will want the engine that matches the ECU you want to use. If you're converting to OBD1 and using a P28, you'll want the D16Z6 equivalent ZC. If you're staying OBD0 you'll want the non VTEC D16A6 equivalent SOHC ZC. I've had both and I felt that the OBD0 ZC was faster, though it was in a 90 Si vs my 93 Civic hatch with the OBD1 ZC.
I'm in USA... I was talkn about the place that I call that import the motors... I was thinkn about just stickn w the OBD0 to keep things simple... But I'm open to suggestions or input on what woul be a better value/ more power
Get an obd0 DOHC ZC!!! End of your problems/worries!!
thats what im talkin about! great motor and the looks of dohc are so overwelming doesnt matter the series they always look great in there! easyer to tune as well 8)
How do the DOHC gear ratios compare to the SOHC?
not that hard if you remember these 3 catagorys.
SO......
.........................................................timing
head gasket and up is 88-89 integra.....belt
.........................................................is
sohc block stuff exept head gasket.......88
.........................................................prelude 2.0si
timing belt 88-89 2.0si prelude
head gasket and all head parts 88-89 intagra
block 88-91 d16a6 civic
this is good info for a rebuild :roll:
Aside from the timing belt and water pump what other MAJOR things should I look at replacing...??? Aside from cap rotor plugs etc...
I would replace both main seals on the crankshaft so there is no oil leakage, timing belt tensioner, valve cover gaskets. I wouldn't split the head from the block unless its needed. Honda is awesome about their head/gasket to block/deck all that stuff, so I would only worry about doing the head when it is needed. Adjust the valves back to factory specs if needed(when the motor is cold) and check timing when it's back in. I would follow standard engine break-in procedures also for whats recommended on new Honda's. Something like keep it under a certain RPM for the first 500 miles aor so and change the oil and filter a couple of times during that.
