help interpreting flash codes (please) (GA)
I'm looking at a '90 integra, which I thought shared codes with 4g civics, right? Getting a weird sequence.
There are 3 discrete length flashes:
short we'll call .
medium is -
long is _
ok, so it's flashing ... . _ ---- ... . _ ----
(3 short, 1 short 1 long 4 medium repeat.)
WTF?
short we'll call .
medium is -
long is _
WTF?
one short is code 1
one long four medium means code 14 i think
I'm prolly buying this car as an organ donor, just want to know what i'm getting into.
thanks.
Num: Code: Possible Cause: Location:
0 Ecu Faulty or shorted, Check engine light does not appear when starting Passenger side foot well
1 Primary O2 Sensor "A" (O2) Open or Short in O2 sensor circuit, bad O2 sensor - More Exhaust Manifold
2 O2 Sensor "B" (O2) Open or Short in O2 sensor circuit, bad O2 sensor Cat. Converter
3 MAP Sensor (MAP) Loose or dirty connection, Short or open in circuit, Cracked or loose vacuum line, Bad sensor - More Firewall or Throttle Body
4 Crank Angle Sensor Loose or dirty connection, Short or open in circuit, Bad sensor - More Distributor
5 MAP Sensor (MAP) Mechanical problem, Disconnected piping - More Firewall or Throttle Body
6 Coolant Temperature (TA) Loose or dirty connection, Short or open in circuit, Bad sensor - More Head, under distributor
7 Throttle Angle (TPS) Loose or dirty connection, Short or open in circuit, Bad sensor - More Throttle Body
8 Top Dead Center (TDC) Loose or dirty connection, Short or open in circuit, Bad sensor - More Distributor
9 No. 1 Cylinder Position (only on 1.6L) Loose or dirty connection, Short or open in circuit, Bad sensor - More Distributor
10 Intake Air Temperature (IAT) Loose or dirty connection, Short or open in circuit, Bad sensor - More Intake Manifold
11 Does not appear to exist
12 Exhaust Gas Recirculation System (EGR) Loose or dirty connection, Short or open in circuit, Cracked or loose vacuum line, Bad sensor - More Firewall right hand side
13 Atmosphric Pressure (PA) Loose or dirty connection, Short or open in circuit, Bad sensor - More Inside car passenger side wall
14 Electronic Air Control (EACV or IAC) Loose or dirty connection, Short or open in circuit, Dirty, Bad sensor - More Throttle Body
15 Ignition Output Signal Loose or dirty connection, Short or open in circuit - More Distributor
16 Fuel Injector Loose or dirty connection, Short or open in circuit, Bad injector, Resistor Box - More Fuel rail, Right side close to firewall
17 Vehicle Speed Sensor (VSS) Loose or dirty connection, Short or open in circuit, Bad sensor - More Left front tire, Transmission
18 Does not appear to exist
19 Lock Up Control Solenoid (auto trans only) - Loose or dirty connection, Short or open in circuit, Bad sensor - More Loose or dirty connection, Short or open in circuit, Defective soleniod valve
20 Electric Load Detector (ELD) Loose or dirty connection, Short or open in circuit, Bad sensor - More Right side shock tower, Built into the Main Fuse Box
