lowering the front of a 85(answered)
does anybody know how to lower a 85
i adjusted the torsion bars to the max but i wanna slam it some more
any replys would be aprecciated
http://www.hondacivicwagon.com/bb/viewtopic.php?t=4509
well you have to take out your torsion bars from the torsion tubes and rotate them a couple splines. But i dropped the subframe to get the torsion bar out on the driver side cuz there was some of the subframe in the way, plus is much easier to work on when off the car. Be sure not to damge the threads cuz you'll have to get new tb's if u do. But make sure before u take out the torsion bar that you make a straight line on the torsion bar and tube so once u remove the torsion bar u still know what the stock alignment is. Time consuming but not to hard
