+++SiWagon DIY:Cheap Custom Tails & Bright Ideas
Rear Brake Lites:You'll notice that there are 2 brake lites on each side.For a more customized look.Remove 1 of the brake lites from each side.I'd recommend removing the 2 inner 1's.
Benefit:2 spare bulbs & less drain on the system.You can put the 2 spare bulbs into the bulb holders built-into the rear interior corner lite covers.Which brings us to the next Mod that'll take some of the power back that we just saved.
Brighter Fronts:Get a pair of rear hi mount brake lites(#921 I think) .Replace the 2 front clear corner bulbs with the #921s.
Benefit:Brighter. & 2 more spare bulbs.8) You'll notice the #921 are larger & brighter than the frt.bulbs.I admit its hardly noticeable,but hey it's forward lighting.
