[EE/EY/EF] Adjustable Headlight Wiring
this is along shot, perhaps... BUT im sure there are some wiring genious on this board, and the following episode you are about to read isnt all that crazy. so here goes....
obviously, i have installed EDM adjustable headlights. this works by a small motor that moves the lens inside the headlight housing. the motor is controlled by a switch in the dash.
NOW.
the switch has 2 wires coming from it. on BLACK and one BLUE.
the headlight motor has 3 wires coming from it. BLACK, BLUE, GREEN.
so now the question is, who knows how these would come together?
my thoughts were that the black and blue wires connect directly together, and the green one is either a ground or a power source.
anyone care to share some knowledge?
NOW.
Now how many people do you think have these things huh????
The green is green/black right?
If it is, mine is running to the fuse box which is 15amps.
I TAKE NO responsibility
nuff said :P
Newer cars here are self leveling.
This adjustment is a REQUIREMENT here in Germany for any car newer than a 1990. Your car will fail inspection if they are not functioning.
Not really. I can't bloody stand not being able to see where i am going because the oncoming cars lights are pointing too high..
edit: i do think the switch looks hot though....
Go mod go, you can dooooowit!
some
all my relatives' cars in Europe have the manual leveling switch, including every rental car we have ever had lolz
its pretty fun. when i show the guys down here they start tripping over it hahaha
oh and evol911, there are pics of it under my rides thread
:roll:
I want to do this mod to my twin bulb headlights which have a different method for adjusting the lens.
I have the switch, I wonder if it's just worth getting the OEM bits or just using stepper motors / servos.
They are German fitment to all Hondas.
that's a plane man...
how's it hangin'
ahaahaaa
LOL
what is this in between lights
it's possible to connect
a dimmer switch...
independant hi/lo beam too...
also schematics...
If the EF8 is the SIR CRX then they would be an EE8 here in Germany and they also had adjustable glass headlights.
