K Just wasn't sure since I didn't see to many people doing that swap.
You mean like this?
In this?
Basically it's no different than swapping into any other 88-91 Civic chassis.
90-93 Integra Engine (or 94-01 engine and 90-93 tranny to keep it simple)
Custom engine mount kits (HASport comes to mind)
Custom shift linkage (again HASport comes to mind)
Matching intermediate shaft and axles from an Integra (90-93 preferred)
Custom a/c bracket if retaining A/C (HASport again)
Fun wiring if the wagon is a DX or Wagovan with the wonderful crap 2 injector system
90-93 Integra radiator hoses
90-93 Integra engine mount bracketry
Then there's the banging on the driver's side frame rail to make clearance for the alternator pulley, and cutting/folding the rear crossmember to allow proper fitment of the rear custom billet mount
It's fairly straightforward, but like other 88-91 EF swaps is more complicated than your run of the mill 92-95 Civic swap.
I love the B18B in my wagon. It's not going to be the dragstrip killer, but for my daily driver it's perfect. I can leave it in 5th gear, a/c on, and pull just fine up steeper hills - something the stock D15 won't do.
Thanks for the info man I was just trying to find it all out I just purchased a 91 Wagon fwd with the 1.5 in it and it's going to be my winter project and I wanted to do a swap. I have many friends who have done motor swaps in Honda's just never in a Wagon so just had to check on it.
You cant do this B-Series swap on a 4wd wagon unless you swap the tranny/whole drivetrain with a 1st gen CRV's.
Also Why does the B18A suck Kahuna? I know it's got less hp than the B18B, but it's still much better than the stock 1.5L mill, and I'd actually prefer a 1.8L non-VTEC in a wagon over a B16A or so due to the weight of a wagon and the torque advantage of the B18A/B.
Agreed!
I am a total believer in the LS motors. Those things can take a beating for years and years on end. I tried to ruin my 91 LS motor for 8 autox seasons wanting to swap in a gsr motor. Countless autox/lapping days bangin off the rev limiter. The first time Ive ever pulled a running motor out of a car, lol.
Ya I am def. doing this swap a buddy of mine is very experienced in doing b swaps and building b series motors. I got the car for 500 bucks with 120,000 miles on it just a little rust above the passenger rear wheel which is normal for the year, ac and everything still works. I just plan on painting it and redoing the interior and a motor swap, mainly with a little other minor things done.
Oh Ok. He has a FWD. :oops: I tell you I love my LS motor. You cant ask for anything better for the price too. My JDM B18B motor cost me only $750 compared to buying any other Bseries Vtec motor. Not that I wouldnt do a B18C5 in my wagon but the torque and reliablility of an LS motor is priceless. Just my 2.
So where is the best place to get a motor these days besides the junkyard? I know H motors has them but a little pricey for what want to spend right now.
That could work since it's three rib, but why use a D alternator?
Lol, I dunno. Maybe if you didnt have a hammer to bash in the framerail? I was just trying to figure out how the other member got a b-swap in a ef chassis without the framerail bashing.
I have the A1 in my Wago --- I'm wanting to add A/C tho. I got a CEL from the 02 sensor (4 wire) that I have to sort out.
You mean like this?
In this?
Would a B18C5 fit in the same way (sorry to interject but I didn't want to make a new topic)
That actually brings up another question, when I see the b18c swaps on ebay and other sites, which ones are they selling usually, cause they're usually advertised as having 200hp
You mean like this?
In this?
Agreed!
What mount kit?
I can't see any way possible that the alternator pulley will clear that driver's side framerail without banging it in some.
I've never done a B swap into an ED/EF/EE chassis without having to make room for the alternator pulley.
Our shop has probably done 20+ B swaps into 88-91 Civics/CR-Xs.
the USDM B18A1 only has 130 hp, versus the 160 of the B16A. plus, you dont ge that delicious 8200 rpm scream and vtack
MMMMM..Vtech
True, and it don't rev near as fast..
B18as are great.. I'm just talking shit.. lol
