can you take the RT out of RT4wd civic?
is it possible to mke it a real 4wd car, so it doesnt switch back and fourth, also do they amke parts to strengthen the drivetrain of the rt4wd civic because i have heard that the drivetrain is extremly weak and with the age ot the vehicle that doesnt mix to well.
And no, without actually welding stuff, theres no way to make it full-time 4wd. You can however switch it into FWD by using a lever under the gearbox..
You can get a spring upgrade kit for the rear diff but thats about all in the aftermarket parts area, best bet is custom fab.
Hope that helps
regardless, the d series 4wd sytem is ok for mods, not apesh!t horsepower. If you keep it round 200 hp you should be good. Maintenace is paramount!
I'm not saying its not worth making it full-time, you just have to decide what you want it for... if you want autocross/cornering/rally etc then you will definately want to lock her up. But if its for street driving and drag racing then RT4WD it should stay...
