ZC valve clearance
I tried to search this on the site but had no luck. I would like to know what the (cold)recomended tolerance is supposed to be for my ZC DOHC cam to follower clearance. I set them at .005" cold. My manual for SOHC suggest .007 to .011, but does not cover the DOHC
Intake - .0051-.0067 inches
Exhaust - .0059-.0075 inches
Sorry I'm a conversion/math retard, or else I'd tell you what it translates into mm.
(Inches) x 25.4= (Millimeters)
If you are converting Milllimeters to Inches:
(Millimeters) x .03937= (Inches)
