help with clutch cable removal
I've detached the clutch cable from the tranny end and all the hooks in the engine compartment. I'm having a hell of a time getting the cable to disconnect from the pedal, though. I wonder if the people who did the clutch on the car used the wrong cable, because it shouldn't be that difficult.
To describe how the system looks, the cable connects in to a metal bracket. The metal bracket connects to the hook on the top of the pedal, and it seems like this should just slide out towards the seat, away from the firewall. The problem is that it's not sliding straight out. It seems to be locked in to the "C" at the top of the pedal.
So do I have an odd setup or have I just not managed to turn this thing the right way to get it out yet? I fussed with it for over an hour with no luck. :oops:
Think of the pedal hook as the "C" you described. If you could see it from the left side, the cable clevis would be pointing to 9 0'clock. There's not enough space to pull it straight toward 3o'clock, you have to rotate the clevis around the C up past noon. Impossible to do unless the tranny end is free, but you already got that, right?
Edit: I think I kind of see what you're saying in my mind now.. it's just a b*tch to get up under there for a full-sized person like myself.
( I just removed the pedal assembly TWICE, I feel your pain!)
So I got the cable out, but I'm pretty sure that isn't my problem. I'm trying to diagnose what's wrong with my clutch.. the car has been sitting for a year since I had a sudden clutch failure (which I've posted about before.)
I checked the throwout arm and it doesn't seem to be doing anything--it takes very little effort to pull the arm up. Like I said, I'm not really sure how it's supposed to act, but I would expect it would spring back if the pressure plate were behaving correctly. I can't shift it into gear when the arm is up either.
So I'm trying to decide if I want to try to do the clutch myself, pay someone $1000 to do it, or sell the wagon for a few hundred. It's an '88 4wd with 185k and it runs perfectly, including A/C. Only problems are the windshield and the drivers window doesn't roll up quite straight. It's got a few dents and slight paint oxidation, but it's rust free and about the best looking Civic wagon I've seen in Colorado. I just replaced the battery and the arms on the hatch liftgate. It even has a nice alpine stereo. I'm thinking of going to a Subaru though for better crash protection. But I think this car is probably more reliable than a Subaru that's 10 years younger.
