Is this the same as an Intrac LSD?
It says it's an Viscous LSd and fits a EG6 Y1 transaxle.
Also stated in the ad:
It has the same bearings, and
bearing spacing as the DC2 LSD.
But because of it's tapered body, will fit more transaxles than the DC2 helical.
Has to be used with a 15 tooth final drive pinion gear because of the 66 tooth spur gear (4.4:1 ratio).
http://cgi.ebay.com/ebaymotors/JDM-Hond ... enameZWDVW
There's also this one which is helical:
http://cgi.ebay.com/ebaymotors/JDM-HOND ... enameZWDVW
