Power steering?
OK, I just got a 4wd civic from the junkyard and I was think about things that I should do to it. One thing that Ive been thinking about is removing the power steering,
that will make the engine bay alot cleaner. Or should I keep it? And is having AC important because I was thinking of removing that too.
Wire tuck will make it look nicer as well.
1. I can remove just the pump and and cap off the rack
2. I have another civic wagon that has no powersteering and I could swap the rack but I dont know if will bolt up the same. its a 89 civic 2wd.
What do you guys think.
AC:
1)It's more for winter than summer.It defogs the front window faster than just the heater.
2)When on long enough it defogs the rear windows too.
3) As a game I use it to slooowww the Wgn down on off ramps,which also helps keep the AC system lubed.
PS:
1)Actually looks good when you clean the bay.It has goldish fittings.
Do a search some have capped it others connect a hose between the in &out.I'm pretty sure u can swap it w/a manual.
and power steering is nice to have if you will do ny city driving. if not then DITCH IT haha. honestly you wont need it unless you are trying to parallel park in tight areas. even then, just lean on the wheel 8) but i mean, if its there, i'd leave it
Jake Brake!
PS doesn't create enough drag to warrant removing it, versus the benefits it provides.
I'm thinking about loosing it. The CRX is manual and its fine once you get used to it. The wagon can't possibly be that much more weight. And besides, one point that no one else brought up, its one less thing to go wrong
I wish someone could go into detail about capping it off or doing whatever
IF you cap it you still have to push against the the valves but the fluid you're trying to move will have nowhere to go because the lines will be capped off which will make it harder to steer. Likewise, if you loop it you will still have to push fluid through the valves. So, taking the valves out and running it looped or dry should net the easiest steering.
I once read how to remove the valves. I'll try to find it again....
Yeah, so taking it as it comes I've decided to take the PS belt off and later completely remove the PS system and set the rack up according to this guys post http://www.honda-tech.com/zerothread?id=184202&postid=1666202
Seems like the best option. Right now w/o the PS belt it feels like the crx. It was weird because I only drive the wagon now and I've become familiar with the PS. Anywho, that is that regarding the PS issue.
For the rest of my plans see my rides thread. http://www.hondacivicwagon.com/board/viewtopic.php?p=35988#35988
I've finally got it in drivable state again, so I can also tell you that the power steering is extremely helpful at a standstill. As soon as I get moving at all -- even creeping so slowly the speedo doesn't register -- manual steering becomes easy enough for my 13-year-old daughter to do it.
I'd ditch the P/S, but I've always been big on simplicity and reliability.
