roof question
i looked around at a lot of other wagons to see if any had the same problem as mine, but i didn't see any.
my roof is extremely flexable, it dents in about as big around as half the roof. i can push it in from the inside but it's still about half way there. if i'm going down the road around 60+ mph the wind and my roof rattle really loud, it almost sounds like a flat tire.
is there some sort of stuff up there that keeps the roof sturdy? could mine be broken?
thanks guys.
thanks guys.
it isnt "broken" though... :?: what it is, is this: the roof has support rails running along the interior of it above the headliner. these are simply glued to the sheet metal of the roof. over time sometimes the glue comes undone and makes your roof flap.
to fix it, take out your headliner. then spot-weld these support rails to the roof sheet metal. this will strengthen it all over again
[edit:] if thats a bit much, then simply glue it. lolz.
WELD them to the roof skin? :shock: ... not.
maybe use some kind of epoxy, or RTV, or cyanurate foam (greatstuff?)
anything, even bathtub caulk would work.
by broken i meant it as in maybe it was screwed in at one time by some kind of bracket and it broke loose.
Try this. take out your headliner and weld just one tack to the roof skin. I'll hold the bets on WHEN (not if) the tack pulls through the skin.
should i just re-glue it?
gorilla glue works wonders, ya know?
On a side note: my roof rack shut mine up, I guess just stiffened the skin, or lessened the free span?
/thread.
I did that, along with all the metal strips that fit in between, and my roof no longer flexes. It also makes a nice mod as the Subaru roofrack looks really old school.
Before doing this mod the roof would boom when a door was closed quickly or it would flex if a window was opened when the car was going down the highway.
I've been meaning to add a few more screws to further stiffen the roof as there is still a small portion of the roof, near the front, that wants to sag.
I used metal screws and rubber grommets to prevent any water from seeping into the car via the holes I drilled so my wagon is still water tight.
njcivicwagon has one, i planned on doing it sooner or later but have no idea on what year sunroof to use.
i envy rich people.
what year and model sunroof should i use? i'd rather use a non-electric one.
but dude, installing a sunroof is a tedious and expensive task. id wait a ways and finish up other things with your car first.
like i said, sooner or later. do it like bam and his ferreri and just cut a big hole
man my skating days are done... have been for a while. it was too painful.
pain wasn't my problem, it was my ankles. they couldn't take the bails anymore. they didn't hurt, it was just under a lot of pressure my bones began to pull apart. my doctor said if i continued skating the way i did and kept rolling my ankles i'd end up in a wheelchair for life.
It is glued so that it will look pretty from the outside, simple as that..
JB Weld it.. That would probably be best.. Unless you can get ahold of some automotive grade glue, like oem..
I've learned so much from school already.. Haha I'm actually studying this right now..
the way it was "glued" i don't know how to get the support rails that were "glued" to stay in place long enough for the apoxy or caulk im going to use to dry.
if i put the glue on the rail and push it up to the roof, im going to have to hold it there until it drys. _-_ otherwise it's going to pull itself apart.
edit:
nevermind, i get what you mean now.
but the calk is too gooey to "fill in the gap"
i did the exact same mod with 4 strips. worked wonders. old subaru wagon roof rack rails. no leaks.
