Engine idles and revs beautifully but makes no power!
So I finished my auto to manual swap a few weeks ago and replaced the engine with a ZC. While it was out I replaced the timing belt and the clutch and all the major gaskets and seals except the head gasket, I also switched out the ECU for the manual unit. It fired up after a few cranks and ran like a champ. I thought I was all set until I took it it out for its first test drive recently and discovered that when going up any sort of incline I have NO POWER! Even in the super low gear it can't get out of its own way. On the flats and down hill it feels fairly normal. It kind of feels like some kind of turbo lag (there is no turbo on the car) because once you get in the higher Rpms it takes off. I was hoping it was bad gas and drained the tank and ran some injector cleaner, as well as replacing the fuel filter but it made no difference. I also replaced the spark plugs and I'm running fresh wires, cap and rotor. I took it over to my local mechanic to check over my work but so far they seem stumped as well. Any ideas?
Those are my first 3 thoughts.
http://www.evans-tuning.com/tech-articles/obd1-codes
It's been 8 years ..... Guess he never found out what it was?
