RSX or TSX shifter into RT4WD.
So my car's shifter is the weak link. The cables are tired, the bushings are worn and there isn't much you can do about it. Or is there?
The RSX and TSX...or any K series motor for that matter also has a cable shifter. I just looked at the RSX shifter and the cable ends for the transmission side look really close, upon initial inspection, to our cables. The OEM cables are adjustable, and if the lengths are not long enough there are a couple places that will do custom cables (K tuned used to do custom cables but not anymore).
So, I'm gonna take the dive and order an RSX OEM shifter and cables and have a go.
RSX and Insight have the front to back cable attached above the shifter pivot point while the TSX has the cable attached below the pivot point. The linkages on the transmission are opposite of each other between TSX and RSX.
Insight and RSX use eyelets or rod end style joints while then TSX cables have a ball and socket joint.
I want to say the Insight cables are a fair bit longer and smaller diameter.
I think if you could change your thinking to get it into first rowing gears would still feel pretty normal but the locations of the gears would be odd. You also loose super low gear as the K series shifter doesn't allow that much travel.
I did just have a call with Mike from K-Tuned and he suggested I try an Accord K series shifter as they have the connection point on the other side of the ball. I might talk with the guys from Vtec Academy as well to get their insight.
I'll update again when I get some more feedback.
Edit: also reached out to Hush performance today.
Ik this is old but any update on how this turned out ?
