Window run channel
Hey guys! So, i need to replace my drivers side run channel. Now if i were to find one on another car, how would remove it? Can i just pull it off? Or is it bolted in and have to remove the door panel and window? Thanks
  • im pretty sure that its a wagon only part and they just pull out. peel it out of the channel carefully u will have to remove the door glass to get it out. simple job
  • cya02cya02 Band Wagon
    invalid wrote: »
    Thank you! I was able to find one at the junkyard!
  • I didn't know that window channels can be removed from a door?
    I thought they were a permanent feature of the door itself.
  • FamilyWagonFamilyWagon Band Wagon
    i removed mine
  • i removed mine
    6 months later to just say you removed yours? Thanks?
  • 8 years later this is still relevant to me, so thanks to everyone that made a productive, positive reply!
