Rear sway bar
Any ideas on how to mount rear sway bar from a DA teg or civic ef?
    you pretty much need everything off the DA or ef beside the endlinks... so sway bar, bolts, brackets that bolt down to the bottom of the chassis, but you'll need 87-88 honda accord endlinks.. but even with those you have to cut off and re-weld to fit the correct direction... i've been look online and i see blox sell some stabilizers endlinks might work...
