A/c Compatibility
Hello,
My car didn't originally come with a/c and Im trying to convert. I'm wondering if someone could tell me if I could use the a/c set up in a 91 coupe or sedan civic. Would it be a straight bolt up? Or would it just be best to get the a/c set from a 4wd wagon like mine.
Thanks for your suggestions.
Thanks
here is a diagram
I'm currently on the hunt for a new/reman replacement for my mom's 1990 Wagon DX, and I think hers is a Sanden if I recall correctly. I'm verifying which it is so I can order the right one soon.
Like someone else already said 88-91 Civics had either make/model compressor - it was literally 50/50 - just make sure if you get one type of compressor that you also get the same type clutch, coil, hoses, etc.
