need brake advice
1991 wagon 2wd: the brake light stayed lit - fluid low
Honda dealer found passenger rear cylinder leaking
Brakes were replaced 6K miles ago at different shop and have lots of life left
Dealer says I need complete rear brake job because of the one leaking cylinder $368
Do I really need everything redone??
It is recommended you do brakes on the same axle at the same time to keep everything even
I am going to check the complete manual I have on CD and see if it is something we can do.
If so I will order all new parts including drums (instead of turning these)
Looking at online parts, there seem to be a lot to choose from, but I guess I will just go for the ones marked "premium" for not much more, and hopefully they are higher quality and last longer.
Would you think that's true or should I be choosing according to brand?
Also, would you repack/replace wheel bearings while you're in there?
Thanks again!
