Mystery stumble/stalling - SOLVED
I need some input... I just put a brand new Weber 32/36 on my 86 wagon. It runs great, except from 3-4K at part throttle in higher gears, it stumbles, backfires through the carb, and falls flat / stalls. If I downshift it recovers, or if I floor it she usually straightens right out and goes. Basically, I can cruise up to 45-55 without a problem on flat ground, but if I hit a hill or want to go 60 or more I am stuck alternating between full throttle and very light throttle.
AFAIK everything is connected correctly, the plugs/wires/cap & rotor are fine. Timing wasn't changed when I swapped out the hitachi, but I played with it and found only very slight improvement with significant retard, so it's currently back to its original setting. I've flow tested the fuel system and have a pressure reg on it at 2.5 psi. double checked the float and fuel inlet. I've searched all over and the only clue I've seen is a blog post showing messed up aux valves and gunked up aux chambers. I've got a cheap scope on the way so I can check that without pulling the head, and a jet kit coming so I can try that, but looking at tuning manuals I can't make sense of why it would have such a huge problem under such specific conditions caused by jetting.
Anyone else ever have this problem? I had an 86 with a Weber on it and it was perfect.
