0bd0 to 0bd1 b20 wagon
Alright so this is my first time posting on here, but I have an 88 civic wagon with a b20 swap, I drive it just about everyday, but I want to convert it to 0bd1 from 0bd0. Do I just need the jumper harness and dizzy harness? Or do I need a new dizzy and ecu?
And do I need the 4 wire 02 sensor?
I'm sure these are some easy questions for someone. Lol
Thanks for the help.
Most likley the 02 sensor aswell but not 100% on that. (buy an old factory exhaust with one? cheaper)
Honda Street Garage are having a sale on B20 questions at the moment. They say start with an B18CR Base map etc and get it tuned from there. Just chip a P08 or something.
https://www.youtube.com/watch?v=q05hHm1Ka0o
https://www.youtube.com/watch?v=7OoE1CdkZvs
Any questions, Keep 'em coming.
Cheers.
Hey thankyou!
Alright so I was digging threw some old parts of mine, I found a p28 ecu, I know that will work for what I'm doing. So check that off the list lol. And I found a brand new b16 dizzy that I bought awhile ago for a swap that i ended up selling, will it work? It was for the jdm b16a. And if it doesn't work, what kind of dizzy should I buy?
And the 4 wire heated o2 sensor is actually only 14.00 bucks so I don't mind ordering one if need be.
Thanks again for the help.
So my b16 one won't work? I've been reading that all the dizzys are the same, just different wiring and mounting. Thanks for the help
And do you know anything about this 4 wire o2 sensor? I found the sensor, but I don't think it plugs into the existing plug that runs to the ecu
So you'll want the normal B20 dizzy OBD-1, a normal B20 OBD-1 ECU and the 02 sensor to match the ecu (2 wire / 4 wire unless u chip it to ignore 02 heater.)
The adapter boomslang for the OBD0->1 at ecu will have a little branch of extra wires like the other 02 wires and vtec etc pig tailed to the side so you can plug the OBD-1 bits that aren't in your factory harness.
The B16a dizzy mount arm is a little different to clear the vtec solenoid, you can use B20 non-vtec dizzys on vtec head if you cut a mounting arm off so if it fits it should work?? (not 100%) cheaper to buy a B20 one than damage a nice B16 dizzy.
the extra 2 wire just has a ceramic heater that preheats the 02 sensor.
Im looking at a 92-95 integra obd1, non vtec 1.8 dizzy, I believe that's what I'm going to go with. Unless I use the b16 dizzy, my b20 isn't vtec so there's no vtec solenoid in the way.
And again thanks for the help guys!
Okay, thanks. I found an obd1 non vtec 1.8 dizzy that I think I'm going to use. And I figured out the 4 wire o2 sensor wiring on rywire.com so I'm good on that.
But thankyou for the help!
Blue - P02SHTC - 02 Sensor Heater Control (02BLK Wire)
White - PH02S - 02 Sensor Signal (02 WHT Wire)
Violet - VTS - VTEC Solenoid Signal
Gray - VTM - VTEC Pressure Switch Signal
Green - IAB - Intake Air Bypass Signal
Orange KS - Knock Sensor Signal
Red or Pink (2) - IGP Power (IAB, 02, BLK Wire)
Black or Brown - (3) -PG Ground - (SCS, VRM, 02 GRN Wire)
Yellow SCS - Service Check Signal
I found these directions for the 4 wire o2 sensor, its for a cheaper ebay obd0 to obd1 jumper harness, but I dont understand this part
Is it telling me that I can hook up EITHER red or the pink to the black wire? And I can hook up either black or brown to the green?
If anyone has any idea please let me know so I can save 80 bucks and not buy the rywire harness lol.
Once again. Thanks!
