Fuel pump options? Do Walbro 255's need after market FPR? What fuel pump r u running?
Whats your current fuel pump setup? Does anyone know if Walbro 255's need aftermarket FPR ( Fuel Pressure Regulator ) I've seen some posts suggesting the stock one and a stock return line is enough to keep the injectors at bey and car from running rich - other suggest the later . What do you got in your Civic? Rt or 2wd? Whats your engine setup? Turbo / NA ?
i cant find any that dont say HP in their name though
