underseat storage tray...wtf
so i got one these amazing and notorious little storage tray box thingies that go under the seat, except now i have no fricking idea how to get it installed, and quite frankly not even sure where they even go i try fitting it under there and the wire for the seat rail adjustment is 100% in the way. can anyone post up a pic of how its supposed to be?
btw, i have a 1991 Wagon..sooo that might make things difficult.
The bin slides completely underneath the seat, and slides out completely if you want it to. But here's the part you're probably missing:
There's a bracket attached to the underside of the seat, separate from the tray itself. My guess is you guys with newer wagons don't have this bracket, which is why the tray won't attach. It looks to be held on with 4 Phillips head screws, so it may be possible to snag a bracket and attach it to the underside of your passenger seat - or driver's seat, for that matter (convenient place to stash the radar detector when you get pulled over...
Thank you for these informative pics.
I know that I am getting the tray and the bracket so installation should go well.
Interesting that you mention installing it under the driver's seat. Sounds like a plan!!
that wire that goes across for the seat rail adjustment.
I just put my wife's tray back in her car. I had mounted a DVD player in that spot :roll:
it seems the 90-91 seats have an extra bulge on the bottom of them...
I've learned that once I swap seats, I should sell someone my tray - AND bracket.
Odyssey tray.
88-89 civic wagon Rt4wd
Discuss
hey quarters, what year is your car?
i managed to install it, but pics wouldnt hurt.
you dont have the auto belts though, so your seat set-up is different. im curious though.
Check out my thread on the comparison. There is a link from where I bought mine
Bad A$$, thanks alot, I am going to go get one & maybe 2..
will this be any issue with the seat slider wire?
