What clutch kit should i get?
I cant find any for the 4wd would the SI kit work ? i need flywheel, clutch pilot bearing and throw out bearing i know the first 3 are the same but the htrowout bearing i think is different. i got a si one coming in tomorrow and then i got a clutch kit coming in on friday and thats for a 4wd so ill compare and let u guys know if any one has the answer post here so i can just return the stuff when it comes in instead if you know the answer thanks.
with not much luck :roll:
Don't give up on searching...
many to pick from here... but gonna need someone with a little know how , to let me know which will work best n SCRAPPY..
http://www2.advancedclutch.com/1381137/0/0/0/1991_HONDA_CIVIC_4WD_L4_1.6L_N_FI_%28D16A6%29.html
You can drill down through the make, model, etc to see what is different. Here is the throwout bearin I needed for my 1990 RT4WD.
http://www.clutchcityonline.com/products/BRG428.shtml
If you compare part numbers, you can figure out what flywheels, discs, pressure plates, etc interchange.
88-89:
Bearing: http://www.exedyusa.com/oe/BRG428
OEM: http://www.exedyusa.com/oe/08710
90-91
Oem: http://www.exedyusa.com/oe/08020
Stg 1: http://www.exedyusa.com/oe/08801C
Stg 2: http://www.exedyusa.com/oe/08902C
Beware of some Exedy kits on Ebay that come with no name Chinese brand bearings.
http://www.ebay.com/itm/EXEDY-CLUTCH-PRO-KIT-fits-1990-1991-HONDA-CIVIC-RT-4WD-WAGON-1-6L-SOHC-I4-/321994341408?hash=item4af85bbc20
