Do 16cl14vn calipers fit on RT Wagons?
Hey eveeveryone, I have searched the internet up and down and can't seem to get a straight answer. I have calipers, pads, and rotors that came off a eg ex civic (92-95).From the research I have done so far it looks like theinside of the caliper has to be shaved down to make them work. I am wondering if anyone has done this and if so how exactly did you make it work? I know ef ex ones will work but haven't seen much about eg ones. I apologize if this is a repeated thread but I can't seem to get a straight answer. Everything I'm finding is for egs or eks. Thanks for any and all info!
There's a guy here in the ATL area that can quote those specs chapter and verse. He goes by brakeexpert on here but hasn't been on in awhile. Maybe he's active on H-T.
Thanks for that, I saw that guys name around quite a bit while doing my research. Im going to try mocking these up and see what happens and go from there. Thank you tough.
Did Stoptech rotors and pads, the wagon actually stops now and have the power and modulation to lock up 195/75-14 BFG All Terrains at will on dry pavement.
Went from this poor excuse for a front brake.
To this.
Rotor and pad side by side.
Damn that vehicle must appear stock mantra. OEM+ is fine by me but wheels and spoiler and other non essential cosmetic mods don't work for me.
I upgraded my knuckles to the DA and then put on an EBC stage 2 rotor/pad for the DA and they fit under a +35, 15" RPF1. So there is a bigger brake option while having the RPF1s.
I think the RT > DA upgrade is 9.5" > 10.3".
The DX and RT are a 9.5" front rotor to start with.
Ahh, didn't know the DX had a 9.5 as well. /themoreyouknow
i did vigor calipers grinded 22mm or whatever the thread said and grinded 97 type r pads ls 93 ' rotors
11.1" calipers with the 9.5" knuckle and a 10.3" rotor is how I made mine work. You won't be able to put the 11.1" caliper on a DA/EX 10.3" knuckle.
Could get fancy and put the dual piston Legend GS caliper or NSX caliper on the stock knuckle and clear 14" wheels. I just happened to have the single piston Legend L/LS (Integra Type R) caliper sitting around.
Negative. The pad is slightly thicker radially but is a bit longer giving greater pad surface area. Combined with the RT/DX knuckle having shorter caliper mounting ears the 11.1" caliper fits very well on the 10.3" rotor.
But yes if you attempted an 11.1" caliper on an EX/DA knuckle with a 10.3" rotor the pad would certainly hang over the edge of the rotor because of the longer mount ears on the EX/DA knuckle.
