No start Issue
Hey guys hows it going. Im having a problem with my wagon not wanting to start(D15b2 DPFI). I live in va and we just had that huge rain/tropical storm come in and dump gallons of water on us. Well yesterday was the first nice day and I went out and started the wagon to let her warm up a bit beforing driving. When i went back outside it wasnt running any longer. I tried to start it and nothing.... just cranking, cranking , cranking. Popped the hood and started to do a little diag. I know I have fuel to the "carb/TB" . I have fire on all four cylinders. And as far as I know its getting air lol. The things is with all 3 of the "parts to start" are there, and Im getting nothing. I checked the ecu for codes and I have nothing. Just the one "hello" blink. And my CEL is coming on and going off so I suspect that the Main Relay is orperating properly. Anyway I was just posting to see if anyone else has ran into this at all. If so can you help me out. Im at a loss here. Thanks for the help in advance.
Are you sure you're getting a strong spark from your dizzy? In the past, after especially wet weather, my wagon has had troubles running. Check inside your cap for moisture, and make sure all the seals are intact. Also, check your spark plug wires, if they get wet, primarily down in the tubes, they won't want to fire. I've had all these little issues before. Basically just had to let everything dry out. Hurricanes do crazy things with water haha.
I just gave RockAuto almost 30 bux for one.
