new wagon needs work!
Hello I recently picked up my first wagon, a red 91 rt4wd. It currently has a dohc zc in it thats knocking baaad. I have sohc zc on the way to swap in. Any tips on this swap?
Also i noticed a leak at the transmission under the plate. This is the tranfer case correct? I read that this usually means those bearings are shot. What are all the parts i should replace with them if this turns out to be the issue?
Any help is appreciated! I will post some pics omce the motor comes and i start working
  • Sorry double post. Site wasn't posting my threads at all then came through. Mod can delete
  • VPTVPT Band Wagon
    Personally I would keep the dohc head and just replace the short block.
    Sorry no input from me on the transfercase.
