JDM B16A OBD-0 Oxygen Sensors
Hey guys, I have a question about o2 sensors...
So I recently finished a B16A swap and kept it OBD-0. As most of you know, it comes with 2 oxygen sensors. One with a green plug, the other white (which has the same plug as he D15).
While swapping, I noticed the "primary" sensor (with the green plug) was a bit busted, and sure enough, after the swap I am getting a code 1 (primary o2 sensor). I tried finding this plug online, but am having no luck finding it.
So question is, is there any difference between that and the white plug sensor? If i were to get a new white-plug sensor could i just splice the green plug in instead? Or is there another USDM car that had this same green plug sensor?
I tried looking this up on various forums and have not really gotten a straight forward answer.. Any help/leads would be awesome.
Thanks!
Thanks!
i dunno if any of this makes sense lol
