rust prevention help
Hello, I need some help with rust prevention please. I own a 90 2wd wagon and for some reason I have to keep battling rust on the body right under the left tail light. When I first noticed it, it was just surface rust. So I sanded it down and cleared over it so I could monitor that area. About a month later I can see some surface rust and what looks like a pinhole rust spot in the same area. What should I do to take care of this matter before it becomes another rusty honda?
But yeah if there was a pinhole on mine I'd want to know what was going on behind there and make sure it's treated cause if you don't get at that, any amount of surface dressing is going to be meaningless.
Amazon Prime FTW!
1:is it a complicated process to remove the windscreen?
2:is the rubber in between the glass and the body something very specific to shuttles?
3 what is the chance of the glass shattering, to remove this infernal rust spot?
The windshield is glued in with a rubber molding on top. The molding is wagon specific, but the generic moldings used by auto glass shops will work. Have an auto glass shop remove the windshield so you can do the work, then have them reinstall it. Otherwise, break out the windshield, do the work and have the windshield replaced with new. My last two have been under $200 installed.
