Front camber adjustment when lowering a wagon.
I am planning on lowering my wagon very soon and I wonder how much the front camber will need to be adjusted for tires to be back to normal?
I plan on buying sk-import upper control arms that allow -4/+4 camber adjustment and I wonder if that will be enough.
I do NOT want a stance / _ \ look but rather a normal |_| performance oriented setting.
I will surely buy rear camber kit as well, but I was just wondering if those adjustments will let me correct the camber when lowering the wagon.
My camber figures;
Front 1.06 degrees
Rear 1.30 degrees
So my adjustment of +/-4 degrees should be plenty then?
