Roller bearing removal to access VC
Anyone know how? Tried hammering and prying. Edit: Carrier bearing.
  • GriftyGrifty Wagonist
    I'd say tighten the bearing down in a vice and give the VC shaft a few whacks. Make sure you keep that nut on the VC shaft so you don't damage it.
  • Seized the bearing up. I know just enough to break stuff.
  • AbideAbide Council Member
    I just held the bearing and popped the shaft out with a hammer. I gave it a pb blaster hose down first though.
  • I used a bearing & gear puller from HF. Worth the money.
